Another heat issue
mr.robi1980
Feb 3, 2022
2018 3500 6.7
I have replaced thermostat due to cold operating temperature, as well as heater core back flush (cuz I was there). Had good flow and fluid was clean.
I have replaced the fan clutch due to fluctuating temperature while driving.
Now that I have stabilized my operating temps, I am still getting luke warm air in the cab. I have scanned the HVAC and all actuators pass.
Getting kinda stumped and any advice would be welcomed. Thanks.
2018 3500 6.7
What are the outside temps and do you have the winter front on?
Is the truck deleted?
mr.robi1980
Feb 3, 2022
Truck is completely stock, no delete. Ambient is -14 Celsius and winter front is on. Gauge says 90 (goes up and down a couple because of thermostat), upper rad hose is at 91, core in is 88 and core out is 80.
mr.robi1980
Feb 3, 2022
Took another truck that is almost identical, except for the winter front and the heat in this one is absolutely annoying. gauge says 88, upper rad hose is 80, core in is 77 and out is 74
The blend door may be stuck, whats the temp out of the vent
mr.robi1980
Feb 3, 2022
all actuators pass though. unsure exactly what vent temps are, but they are considerably less than the compared truck.
Does not matter if they pass the test on the scanner the motor could still be moving but the door not moving check the vent temps see what kind of variation across them
