Aisin AS69RC
DP2016
Jan 22, 2022
2016 3500 SRW. Check engine light came on after a hard shift when I was cruising on a highway at about 75 mph. Check engine code was P0970. Mechanic said a solenoid failed but had to replace to while valve body since we still can't buy just the solenoid. The new valve body is in but going through the relearn process, it keeps failing. The Mopar mechanic doesn't know why... Anyone have experience or advice?
gt1guy
Mar 6, 2022
New Iberia, La.
Sorry, no help as per your question. But can you describe the shift you said was hard a bit more? If at 75mph, was it an up shift to 6th, or a down shift to 5th? Wide open throttle?
WRCLVR
Jan 20, 2022
so how is the quicklearn process performed? 2017 HO WITH AS69RC
R.Duff7
Sep 6, 2023
I tried it in alfaobd and it just wouldn't do it. I had to take it to the dealership for them to do it.
