37 Micky Thompson bajas
Arvid
Mar 2, 2023
Anyone have 37” bajas on their stock suspension power wagon?
I think these will be my next shoe change and i’m teetering between 35’s and 37’s
2022 PW
Shake N Bake
May 2, 2021
I had 35" Baja ATs on my stock wheels and stock suspension. It would rub slightly while offroad but could be easily trimmed. Before switching to 37" Baja ATs and a Thuren suspension, I tried to fit the 37s with the stock suspension. It rubbed while backing out of my driveway while the wheels turned. May work if you trim a little, but not sure if it would work while the sway bar is disconnected while the front end flexes.
UglyViking
Jul 11, 2020
You can run 37s on stock suspension no problem, it's the stock wheel offset that is the challenge. The OEM wheel offset is somewhere in the +44mm to +54mm range, which means that when you put on 37s (which generally are 12.5 to 13.5 wide) you're extending that in even further. The recommended wheel offset is +18mm to +25mm.
If you're dead set on running the OEM wheels you can either run a narrow 37" tire (I believe mickey makes a 10-11" 37?), you can change the swaybar to a Thuren high clearance swaybar and Thuren/Carli/FirchFab radius arms, or you can deal with the rubbing and potentially lose a little turning radius.
Arvid
Mar 2, 2023
Thanks guys. All good info.
I’ll post pictures once I decide and get them mounted.
Skid51
Oct 17, 2023
I’d love a 37x11.5R17 in a MT BB AT on stock rims but I believe the only availability in that size is a Nitto Recon. I do want a 3MPSF which the Recon is not.
Arvid
Mar 2, 2023
How hard is it to change the wheel offset?
UglyViking
Jul 11, 2020
I don't know if you live in an area where a 3PMSF is a requirement, but those recons look like they would do decent in the snow, just going by their lug spacing. Perhaps look into some reviews if having the icon isn't a hard requirement?
Past that, it looks like I was thinking of 35s for my dually, and not 37s for my 2500. In which case you're basically gonna be running a 12.5 wide on any 37.
You don't change wheel offset, you just buy new wheels. In order to get the correct offset on the OEM wheels to not need high clearance radius arms and swaybar, you'd have to run something like a 0.75" spacer, which is not something I'd recommend at all as you're just losing thread engagement on your hubs.
Enve46
Jul 20, 2021
I would upload a picture but I keep getting an error saying image file is too large, guess something changed in this site?
Anyway, I run 37x12.50 Geolander MTs, stock PW. Minor rubbing. I’m also running AEV Salta wheels which have proper spacing to fit 37s. There’s lots of good reading out there on Thurens website on wheel offset, take a look at that cause I learned a lot.
Skid51
Oct 17, 2023
Not a requirement here in the Cdn Rockies but given I ran dedicated winter tires 6+ months of the year on past trucks I feel 3PMSF is a minimum threshold for a year-round tire. Research on the Recon doesn’t uncover anyone raving about snow/ice performance and just visually you can see it has noticeably less siping than say a Baja Boss, Wildpeak or KO2. I think I will take this in steps: replace the OEM Duratracs with 35” 3PMSF A/T’s (MTBB’s or Wildpeaks), see how they work for my purposes (everything from black ice to highway towing to annual Moab trip) and, then when they are due for replacement, make a decision on 37x12.5’s + new rims with the needed offset to run those tires.
tchur1
Jun 23, 2021
My brother has the Baja boss ats in a 37 on AEV saltas (+27 offset I believe) and stock suspension on his 22 power wagon and had no rubbing issues whatsoever. Truck is an absolute tank in the snow on that setup.
Cloudx92
Apr 9, 2023
im rocking a set of 37 x 12.5 x 17 Baja Boss's and i love them! i got the CJC method exclusive rims and i have a TINY bit of rub on full lock on inclines; but other than that theyre amazing! i am considering going to 38 x 13.5's
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
Pics
Docwagon1776
Oct 29, 2022
For the guys running the Mickey Thompson Baja Boss AT tires in 37", what load rating are you running? I can only find 37's with a "D" load rating.
I don't think they make the "E" in the taller sidewalls. If you get a 20" rim you can get the 37" in E, though.
GA Jet
Jan 10, 2021
for those that have run both 35's and 37's on a stock suspension, which do you prefer? I'm on the fence, because the truck looks great on 37's, but you lose a lot of flex (I imagine), and that is something I like abouut these trucks. To be honest, I dont use it now that I am on the east coast, but I like the confidence I have in my trucks abilities with the wheel travel. Does anyone regret running 37's?
