Gondul
Prince of Pintops
Changed the transmission fluid @ 72K miles.
Minimal towing of the TT so I was ok with waiting this long.
Picked up a MOPAR filter as it came with new hardware (also had 4 magnets) and I couldn't really find a solid/consistent review on the Dorman (which apparently can have only 2 magents), wasn't interested in a metal/bigger pan.
Used AMSoil Signature Series Fuel-Efficient Synthetic ATF vs Lifeguard.
Original pan did indeed have a drain plug... dumped the old fluid and removed/installed the pan while it was cold and on the ground.
The Lifeguard smelled fine, though it was a bit of a darker green than what I see for new fluid online.
Jacked up the rear, and filled, ran the truck and 86-122 degrees was *plenty* of time to go through the procedure and get back under the truck to re-fill.
The only thing I will say is that I had to jack up the rear *a lot*... (yes, the driveway is pretty level) had to put a 4x4 on the floor jack to be able to get it high enough and even then I was a smidge off level. Also will be draining/refill one more time to get more of the old fluid out.
