WTB: 2019+ LED reflector headlights
sn_85
I have a 2022 BH 2500 night shade with the halogen headlights. If you have a set of new(ish) LED reflector take-offs I'd love to buy them from you. Would prefer nightshade or blacked out housing but would consider the regular white/chrome ones. I'll cover shipping as well obviously. Let me know what you got. I'm located in Boise, ID.
Someone local to me is selling a BNIB set of LED headlights on Facebook. He's listed them at $2800 and/or trade. If you're interested I can send you a link.
Check BAM Auto Parts. I got a set, Black for 979.00 Shipped no Tax.
Part NamePriceQuantityTotal 68360179AC Headlamp, Left $489.51 68360178AC Headlamp, Right$ 489.51
Those are probably the higher end projector LEDs which I think are on the Limited's. Not sure those would work with my big horn without some harness trickery. Plus a bit out of my price range for lights. Thanks for looking out though.
Thanks for the info. Did you use AlfaOBD or a harness to get them to work on your truck?
If you just get the regular leds nothing else needs done other than plug them in and change the settings
You will need to use Alpha to change some settings. Check out this Thread.
Halogen to OEM LED swap​
Jimmy07 has them listed. I have yet to install mine. I also have a BH.
CBC features LED low beam lamps present- YES
CBC features LED high beam lamps present- YES
CBC features LED front park/marker lamps present- YES
CBC Config I/O Usage front park/signature lamp left pin A7- YES
**2014 CBC Config I/O & Feat. Front park/signature lamp right pin A5- YES**
**Note** If you do not see this 2014 CBC setting, then use this one:
2014 CBC Config I/O & Feat. Truck bed lighting feature- PRESENT **
CBC Extern.Light Calibr.: Signature light present- YES
reflector leds are 12 pin, same as the reflector leds. follow the directions above and it's basically plug and play. adaptive housings are 18 pin, and take a harness plus one wire ran, I believe.
