Great White North Eh
Squish Cat - And So
Ya sipes are fabulous until you chew them across enough gravel. It‘s hard to find the right combination when you live in the sticks.
Its called an ATV, tractor, snowmobile, truck, suv and a good sick leave program at workIt‘s hard to find the right combination when you live in the sticks.![]()
And its only getting worse. Automatic braking will be mandatory on all new vehicles soon...Traction control, I laugh every time a salesman points it out. My response: “I have all the traction control I need at my disposal, it’s called my tight foot!” And the electronic version can get you stuck. Heck, in ten years, the average person will be too stupid to drive themselves.
Yeah, I hear you. I drive 7 miles of rough dirt before I hit any pavement, and if its not covered in snow, my snow tires take a beating. I live pretty high (8,500 ft) and we get so much snow and ice that the snow tires are worth it for me. But I understand that we all live in different places! Both Goodyear (Wrangler Duratrac) and Cooper (ST Maxx) make an AT tire that can be studded if you find yourself on a lot of ice, but also want a tougher tire than a true snow tire. The rubber compound in these two AT tires is harder/tougher than the rubber you find in snow tires, so it won't give you the same grip in winter driving, but it will last longer. The Cooper ST Maxx will probably hold-up better to the gravel you drive on, and it has a tougher sidewall than the Wrangler Duratrac - if that matters to you. Also, the Cooper is made in the USA - and its always good to support domestic manufacturing. There is a little siping in the St Maxx, but not that much. Unfortunately, they aren't giving these awayYa sipes are fabulous until you chew them across enough gravel. It‘s hard to find the right combination when you live in the sticks.![]()
You may want to stay quiet if you want to get "lucky"!Ok, since nobody has said it yet.......I try not to mention winter bed weight when the wife is around.......did I really say that out loud?
I live a bit Southeast of Lake Ontario, we get snow by the yard, it seems. I just use the 4H lever. But when I drove the feed truck (tri-axle) I carried rock salt for traction when the hot tires needed to climb a driveway.Ya sipes are fabulous until you chew them across enough gravel. It‘s hard to find the right combination when you live in the sticks.![]()
That the reason that they put the fuel tank on the DRIVERS side.... counter balance.Ok, since nobody has said it yet.......I try not to mention winter bed weight when the wife is around.......did I really say that out loud?
