Will 17" wheels clear the brakes?
WXman
Kentucky
I've got a set of practically new 35x12.50R17 tires. But will a 17" wheel fit the new Rams? Or are the brakes too large?
Well apparently the Power Wagons use 17s from the factory. I didn't realize that. So the answer should be yes!
Some won’t, also if you use a 17” wheel make sure that the tire shop makes sure that any stick on weights they use won’t interfere with the calipers. I had to have them use low profile weight on my AEV wheels.
