Which fuses to tap into
2500ltd
Hey all. Wiring an ARB Twin Compressor in my 2500 Cummins. Need to tap into ‘illumination’ and ‘ignition’ circuits. I have add a fuse Micro2 wires and will go straight into the fuse box. Any suggestions on which specific circuits to use? Thanks I’m advance for you answers!
Are those going to relays, are they just trigger wires? Amp draw?
They are trigger wires. The IGN one has to be a minimum of 8 amps and the illumination one has to be 5 amps. ARB suggests the illumination one be on the instrument cluster circuit.
F88 is instrument cluster, there are plenty of IGN sources.
F90/F91 is a selectable fuse for the in cab USB power, I think this includes the dash top 12V port but could be wrong..
F88/ATR (Micro2)15 Amp BlueInstrument Panel Cluster
F90/F91/ATR (Micro2)20 Amp YellowIGN or BATT Customer Selectable – If Equipped (HD Only) Power Outlet (Rear Seats) Customer Selectable (DS 1500 Only)
F93/ATR (Micro2)20 Amp YellowCigar Lighter - If Equipped
(sorry forum won't allow the whole table - too many chars)
