Thank you. Sounds like you know your stuff. What are your parameters for transmission temperature while towing?Check "Towing Tips", page 349, in the owner's manual. You might be surprised.
The owner's manual implies engaging tow/haul in "hilly areas." I would add strong headwinds, starting from a stop and excessive shifting to that (add changing trans fluid on time or before maintenance schedule).
Rules I lived by when I pulled a fully loaded 6x10 cargo trailer multiple times with my 92,000 mile 1500. Apples to oranges, I know, but it was still shifting strong the day I traded it in.
Hate to be contrary to what is already said, but pulling that whiff of a trailer down the highway and watching your trans temp, along the way, I would say the tow/haul is not needed unless... Read my second line in my reply.
At the same time there is no harm in running it in tow haul either....Check "Towing Tips", page 349, in the owner's manual. You might be surprised.
in short, changes the shift points in your transmission to keep the truck in an optimal powerband longer. Useful for when you are hauling heavy. keeps the tranny from shifting up and down continuously when your truck is laden. Try it now, you don't have to be towing to use it; you'll see/hear a difference- especially coming from a dead stop at a traffic light.What does tow/haul mode do?
Turning the exhaust brake on full does the same thing i find.....Tow haul also engages exhaust brake on the downshifts when slowing when exhaust brake is activated.
Tow haul is to change the shift points to keep the power longer to keep the constant shifting in doing so it keeps the heat down which make the trans last longer because heat is the #1 trans killer
That was my point, the aggressiveness. The best reason ever not to buy a hemi, is the exhaust brake for me.The EB always engages if enabled. Tow haul engages the exhaust brake more "aggressively" (downshifts sooner) in TH, even when full on.
None of this matters to the OP that has a Hemi.![]()
Hmm good to know i never really noticed i always have in full EBThe EB always engages if enabled. Tow haul engages the exhaust brake more "aggressively" (downshifts sooner) in TH, even when full on.
Me too. EB always on.Hmm good to know i never really noticed i always have in full EB
Why do you people go to youtube for research most youtubers just post opinions not facts and they are usually full of itInteresting...
