No but bumpy roads will throw it out at times so with a fresh set of tires a quick check is never a bad thingTires have nothing to do with and will not change the alignment....
True... an 8,000 lbs truck is not my 1st choice for off road use, I have a couple of old diesel Landcruisers with solid axles that I use for that.With a 2WD, I'm assuming you don't see much off-road action to knock things around.....
Yeah, not knocking the choice at all, just qualifying the response. I beat up my suspension quite a bit during the summer camping/fishing and then again toward the end of the year hunting, so I rarely can go a full year without an alignment, so when I'm getting close to needing new rubber, I try and line up the timing if I can.True... an 8,000 lbs truck is not my 1st choice for off road use, I have a couple of old diesel Landcruisers with solid axles that I use for that.
Depends where you live i guess but here we drive on whats left of the roads so its almost the same as off road lol, honestly we have many more logging roads that are smoother than our highways, city streetsWith a 2WD, I'm assuming you don't see much off-road action to knock things around, so if sticking with the exact same size and things have worn well, I'd leave it alone. If going up in size, I'd get the alignment done.
finding a good reputable mechanic you trust to do the work correctly.
