huff2462
Total newb question: I know we have a 2.5" receiver. What length/diameter locking hitch pin should I order?
(I'm looking at Trimax locking pins)
Thanks for the info!Standard ones work. 5/8" . So if you have had a hitch in a vehicle with a 2" receiver it will work.
I haven't found any extended length yet...but I also didn't look real hard as mine from my 99 and 03 work just fine.
I did however go to a 2.5" drop hitch so I didn't have to use the sleeve...but it moves around just as much as a 2" with the sleeve.
The 2.5" stuff has higher ratings though...and make sure you get the right ball aswell...if the ball capacity is less than the hitch the ball weight is what makes the max capacity.
My question?You know the answer to that question or you wouldn't have asked it.
I’m not sure if I should trust it to tow. Is a hitch pin a hitch pin or should I order a name brand online?
