What is this? Sway Controller?
Dirtstiff
Oregoneifornia
Pardon my lack of knowledge on these newer 3500 Rams, but is this electronic controller on the top of the left front shock / coil spring, for sway control?
I'll do some research.
TIA.
I don't think it has anything to do with the suspension functionality. If that's the ABS pump, that is a dumb place to put it. In Michigan it would ber rusted in a year :oops:. It does resemble the ABS and is also in the area of where the brake master cylinder is. Engineers... :rolleyes:
Hmm. I have something similar on my PW under the truck behind the front wheels that's the anti vibration modules.
Maybe if he posted a picture from the top, we coukd have seen the brake lines running to it
But from that picture, it looks just like the vibration modules on my truck.
The anti vibes are under the cab the ABS pump is on the triver coil bracket
I outlined the “electronic controller” that the OP is specifically asking about in the pic below. If this is the same thing that you are also referring to, that is the ABS module. This is not some guess that I’m making.
The active vibration cancellation modules that you are thinking off are mounted on the frame behind the front tires.
Is that for all 2019+ in terms of location? I have never noticed that before, I had to go look, but there it was on my 2024. Learn something new everyday.
Thanks everybody.
I knew my Gen 2's inside and out.
No need to get rude about it.
I know the vibration dampners have been placed in different spots over the years. Since you can't see any hydraulic lines connected to it, it looks very similar to the vibration dampners.
