2024 Laramie 3500 mega cab HO with airbags towing a 2021 Dutchman Yukon 421FL.
What do you think? Too much? Pulls great rides good.
B&W Companion Slider modelNumbers look good, but I’m a little surprised your front is that low. What’s your hitch setup?
HahaScales are for fat chicks…hook and book…![]()
Nope I have it all the way to the front. I went with the slider so I can adjust all the way to the back because I have to jack knife it hard to get into my storage lot.Is it setup with the pin behind the axle?
This is where it rides.Interesting, your front axle weight is about 300lbs less than I would have expected for that setup.
I weighed the truck with the 22K fiver and my front axle was 5320. Factory installed hitch. Without the trailer, front was 100 pounds less. Obviously not much (if any) pin weight is transferred to the front axle. FWIW, this is a rear wheel drive dually.Numbers look good, but I’m a little surprised your front is that low. What’s your hitch setup?
