NightTrain
About a month or so after taking delivery of my truck, I started to notice more wind/road noise coming from the drivers side. Didn't think too much of it until I took it to the car wash to pressure wash the heavy dirt off the sides. That's when I noticed the water/soap had worked it's way under the bottom of the door and into the cab and that was after a quick pass with the wand. The wind noise is subtle but, definitely noticeable - almost as if the window is not seated all the way up. I checked all the door seals and they seem fine, making contact with the door and attached correctly. Anyone else experience this and know what the fix is, if any?
On another note - it's going to the dealer tomorrow for a separate warranty item. When I installed the leveling kit, I found the drivers side wheel bearing had a little play in it.
