Warning check service ABS, air bag, Trailer brakes
copperman
So two weeks ago ABS, Air Bag, Trailer brakes warning message came across screen. Has done it two more times and the last time "service shifter" message also came across. When I shut the truck off to try and reset, the shifter nob wouldn't shift out of Park when I restarted. After letting truck sit for awhile I could shift into drive, A check engine light came on and stayed on. Dealer has scanned it twice now and stated that its losing communication with computer. Appt set for November 27 for service. Its a 22 Tradesman 6,4 Any experience similar issue. Truck only has 8,500 miles on it
no one?
So see what they say on Monday, sounds like a ground issue or loose/broken wire
Pop the hood and check your fuse box, I found on mine many of the fuses were not completely seated. I just took a screw driver and gave each a good push down, quite a few were not down all the way. Dealer told me these trucks are shipped with only a few fuses installed, Dealer installs most, safety/shipping thing I guess.
The dealer is incorrect and i would be leary bring my vehicle to them if they are willing to lie about something so mundane the fuses are installed from the factory the robot that installs them does not insert them far enough.
Did you get any answers on this issue? I just had the same thing happen to me the other day and then again today. I kept an eye on temp and battery gauges while the warning lights were on and then after about 10 minutes it went back to normal except check engine light stayed on. I should note that check engine light was already on due to a thermostat issue that has already been taken care of.
So i had the same issue. I had it once years ago and replaced the Wheel Speed Sensor on the right front wheel it went away. Then it came back.
I replaced the sensor again but the issue did not go away this time. Brought it to the dealer and it had a wire from the wheel speed sensor that was hidden behind the wheel well that had had rubbed against my front leveling kit bolt!!! . If i traced these wires a little farther mavbe would have noticed it...maybe.
So my advice is to see which wheel speed sensor is the code originates from and trace all the wires carefully.
