Southerncomfort007
Started with 2019 Ram 2500 with 5" screen and manual dials/knobs for HVAC.
Upgraded center stack with a 12" and module from an 2022 Ram 1500
Did the normal disable ICS and enable DCS using alfaobd. Everything works great except backup camera. When I shift in reverse, screen goes blue and says check all surroundings. Also, did the change on head unit screen dimensions with no luck in alfaobd.
Swapped back momentarily to the 5" and camera works fine...
Anyone else had/have this issue and found a workaround ? Starting to wonder if the 2022 Ram 1500 camera transmits in a different video format than 2019 Ram 2500 camera....
