Unable to Reset Fuel Life
MaxRogue
I own a 2024 Ram 3500 6.7 HO.
I changed both my Fuel Filters. I primed the system several times and the truck runs fine. The problem I'm having in setting the Fuel Life Monitor back to 100%. I located the Fuel Life screen and selected YES for resetting and held the OK, but nothing happens. The Fuel Life still reads 70%. Please Help?
I also changed engine oil and filter and was successful in resetting the oil life back to 100%
Just a thought, did you trying cycling the truck on then turning it off then back on and trying to reset it again? Not a clue if that will even help but being so new, I’d take it to the dealership and let them look at it if you’re still in warranty.
Thank you for your reply. I did cycle the system several times with the same outcome; not able to reset the fuel life. This is the second time I have replaced filters, the first time I was successful in resetting the fuel life monitor. this time, no go. I guess I'll take your advice and go to dealership.
Just to confirm, the engine is off with the ignition on (not ACC) correct?
Thanks for the help. I'm reluctant, but probably will have to take it for service at Dealership
