UConnect4 12" NAV Radio Module Connections
Brutal_HO
The Mad Irishman
Staff member
Douglas County, CO
@Jimmy07
Could you please post what each FAKRA and cable header connections are for on the UC4 12" Radio Module? Can't seem to locate a good source.
Everything appears to work (though I don't use cellular) but one of the connectors seems awfully loose since it saw the dealer last and they were in there.
TIA
Looking at the back of the radio, from left to right:
Purple- cellular 1. This one goes to the shark fin on the roof passenger side
White- am/fm radio. This also goes to the shark fin on the roof passenger side
Mustard- SDAR/GPS. This goes to the puck on the roof driver side.
Pink- cellular 2. I’m not sure if it’s the HDs or 1500s that get this one, but it goes to a puck style antenna mounted behind the screen under the dash.
Red- digital camera input for standard backup camera, or surround view system when equipped.
Green (bottom left)- WiFi/BT. This goes to a bar style antenna by the glovebox.
White (bottom, not a fakra)- LVDS. This is the low voltage differential signal cable that links the radio module to the screen.
