UConnect 5 Retrofit Questions
rfullen280
I've searched and read a bunch of threads - so I'll post a new thread to really mess things up.
I'm going to retrofit/upgrade my 21 2500 from Uconnect4 to Uconnect5 -
The questions I have are - CVPM 56029965AC is the one needed to keep the 360 camera, correct?
And then if I want to keep my TTPMS working - do I need to replace both the Gateway and Bumper modules? Are these the correct part numbers:
68404893AB Gateway Module 68526635ab - Bumper Receiver
Any other weird/quirks? How about obtaining software updates?
I think that's it for now...thanks for any/all help.
(not worried bout losing Sirius Guardian - overpriced anyhow)
I don't remember the part number of my CVPM, but IIRC I only had to change the bumper module, if i had to change anything at all. It's been a while now so I can't really remember.
Couple gotchas though that I do remember, when you do the swap, to get the cameras working you're going to have to change the model year in your BCM to 2022+, and if you have a Sirius plan that has the traffic & weather plan on it (Or Possibly anything other than just Satellite radio) sirius will not be able to get your UC5 radio to pair, you have to strip down the subscription to just satellite radio.
Thanks!
Have you had to update your Uconnect Software, and if so, where did you get it from? I assume that Over The Air updates don't push to you...
Thanks!
That is correct OTA updates do not work, but it's no big deal, they barely work for people with factory UC5's. Anyway there is a link floating around on the forum here somewhere to a google drive account that has an archive of user contributed updates. If i find it I'll add the link to this post.
Thanks! And if you think of anything else useful... I'd appreciate anything ya got to share.
do you have to change the BCM year to 2022 to get the backup camera to work or does this just apply to 360?
I think you gotta change it to get any of the cameras to work.
I can confirm that now. BCM to 2022 and recalibrate the camera. If you don’t recalibrate the backup camera is just a blue screen.
If you don’t change the BCM to 2022 you will not see a backup camera option nor will anything happen when you go into reverse.
I can't get the calibrations to work. Good reverse image, good views of the side cameras, and the front...but I'm getting this error... IMG_7035.jpeg
Finally got the cameras to calibrate - had to "clear faults" then start the process. Worked good doing that in order for Left Camera, then clear faults, then Right Camera, clear faults (each time disconnect/reconnect), then Front, clear, and then rear. I used a hardly used road at the county airport, and drove right down the center line so the camera had the dashes to look at.
How is everything working out? I'm about to retrofit my 2020 Limited with XAK surround view to UC5. I have a new radio module and 12" screen for a 2024, the Ebay retro harness, and the needed new CVPM module part # 56029967AF that Infotainment mentions. So I'm assuming you just unplug the old CVPM module and plug in the updated one? Looks like the camera calibration is going to be a pain in the butt. Plan to also do the digital cluster retrofit too, so hopefully the navigation from the UC5 will display on the digital cluster. I have Alpha OBD so I can change the BCM year to 2022. Any help or pointers would be appreciated, sir! Thank you!
go to a long parking lot with parking lines before starting the cvpm programming. make sure the the truck can see the parking lines on both side then start the reprogramming. thank me later
