Turn signals cancels and engages opposite direction?
motorhead426
Southeast Michigan
So I've noticed my new truck likes to engage the left turn signal after the right signal completes. After completing the right turn, the stalk resets so violently that is toggles into the left signal position. I assume gravity is helping here because I don't notice it after left turns and engaging the right signal. Anyone experience this?
Talking about turn signals, when a got my '24 Big Horn, I was disappointed it didn't have passing blinkers where you tap the stalk and it blink three times. Turns out it does have it, but the stalk is so hard to push that it activates normal signals. I have to slowly press on it to get the three blinks. I wonder if there is a solution.
My 25 just did this the other day, but it was when I turned right then had to immediately turn left. It worked out well in that case lol.
Do you happen to have/remember the tsb for that? My brand new '26 just did that. My '21 1500 never did, not sure why the HD's do??
Sorry I do not, I did a quick search and I'm not seeing it right off. If you dig into the posts on the forum I'm sure someone posted it at some point.
My 25 does that, usually only when it auto resets after turning. Strangely it doesn't do it all the time, so when I tried to demonstrate it to the service dept, it wouldn't do it.
I only notice it when I'm turning the wheel 'left' quickly to straighten out from the turn.
Just had mine (2024 6.7) repaired in January. The recall is D5A, NHTSA #23V-799. Hope this helps you out.
