Turbocharger Underboost 19-20 6.7L
Epsilon Plus
February 2, 2021 MANUFACTURER COMMUNICATION NUMBER: 18-009-21
Components: POWER TRAIN
NHTSA ID Number: 10188798
Manufacturer Communication Number: 18-009-21
Summary
Flash: Powertrain Control Module (PCM) Updates
This bulletin involves reprogramming the Engine Control Module/Powertrain Control Module (ECM/PCM) with the latest available software.
Customers may experience a Malfunction Indicator Lamp (MIL) illumination. Upon further investigation the technician may find the following Diagnostic Trouble Code (DTC) has been set: P0299-00 - Turbocharger Underboost.
Summary
Thanks for the post. I have the older CP4 pump. I have not had the described problem or code yet, but if I do I will know there is a fix, that is, replace with the new CP4.2 pump. Maybe by that time it will be, replace with a CP# pump instead.
This post is about an ECM update for people who get the Turbo Underboost MIL.
The part about the pump in the TSB is only for the techs to choose the right version of the new ECM update based on what pump type the truck has. They must visually identify the pump style to choose the right ECM flash. All 19-20 HD 6.7Ls have a CP4.2 but there are two different styles of them. All the info about pumps can be found here:
My error, old age and speed reading. No replacement, just select the correct software.
Thanks, appreciated.
