Can you? Maybe. Will you be over the GCWR and payload for your truck, absolutely.I have a 2021 Ram 2500 diesel Laramie crew cab long bed. Can I tune it and put bags on the rear end for it to be able to pull a fifth wheel with a loaded weight rating of 18,350 lbs and a hitch weight of 2,950 lbs?
Correct I have no doubt about that. That’s y I was gonna put a 7k lb airbag system on the rearBetter look at your payload sticker on your driver door. You’ll be well over payload capacity. Will the Cummins pull it? Without a doubt.
5k is plenty your tires cant even handle 7k….Correct I have no doubt about that. That’s y I was gonna put a 7k lb airbag system on the rear
