True ground clearance with 35's and 37's
areuriding
I'm trying to get a true measurement of ground clearance on the PW with both 35's and 37's. Anyone have this? I know I can add the difference to get the answer, but I wanted to see if anyone has actually gotten true measurements of ground clearance.
It's going to be different from tire manufacture to tire manufacture. Also will depend on tire pressure.
Are you looking for a particular tire?
And everyone who responds should measure at the same spot. Say bottom of the diff front and rear.
on my 2020 Toyo 35x12.5-17 mid 30's psi just a fraction under 10" at the front diff parked on smooth cement.
11" to bottom of front diff. I'm running 3" carli fronts with a modular bumper and a 13k winch.
Where the hell did this guy get his info from??
The end result is 14.2 inches of ground clearance – up 1.1 inches over lesser Ram 2500 4x4s and 2.2 inches more than the Raptor – as well as handy off-road features like a disconnecting front sway bar, locking front and rear differentials, and a standard front winch.
Email: [email protected]
Occupation: Senior Editor
Vehicle Model Date: 2022
I like the frame measurements. i got almost 22" of clearance, clarance! :D
My Carli front diff cover is just over 10" with Mickey Thompson Baja Legend MTZ 37" tires. Frame sits at 22" with Carli Pin-top.
'21 Power Wagon. BFG 35x12.50 17vl on stock beadlock rims.
45/37 PSI.
10" F/ 8" R at bottom of diff.
