b1lanc
Not sure what sub-forum this might fit in. I've noticed this since day one when trying to line up the gooseball with the Goosebox. On flat and level ground the truck will move maybe an inch or less - sometimes forward and sometimes back. This happens with or without the emergency brake engaged and I then have to re-adjust to drop the hitch. But, this also happens in my garage on a slab with nothing attached. I have very little room front to back in the garage bay so I try to get as close to the wall (backing in) as possible. Putting the truck in park, it has rolled both forward at times and back - even bumping the wall on occasion with the Emergency Brake engaged. I've never had any vehicle 'relax' after putting in park and taking the foot off the brake pedal. Anyone else experienced this? I would have thought there would be no movement with the e-brake engaged but there is nearly every single time. The E-brake is fully functional otherwise.
Thanks,
John
Thanks,
John
