24Megacab
As many have already read, my truck has been at the dealer for an output seal and then again to a different dealer for the transfer case seal itself. I noted a small leak from the new output seal now that the case halves were resealed. My question is: is the pressure/weep hole, on the output seal, supposed to be at 6 o clock (bottom) which is where it is leaking from. I read that the hole on the seal should be somewhere between 10-2 o clock (upward toward floor pan). I suspect it should be upward and that this leak is only now presenting because the second dealer actually remedied the issue of the transfer case seal leak. The weep hole likely wasn’t leaking after the first dealer botched the job (by only replacing the output seal) as the transfer case was still steadily leaking at that time. Thanks in advance.
