Last week on a towing trip with my only 8,000 lb. TT, there was a long grade of freeway with lots of traffic. Near the bottom a semi pulled out to pass another semi and both lanes slowed to about 35mph for most of the uphill grade. My truck was running in 4th gear at about 2000 rpms or maybe a bit less. The thing is that in this gear the trans temp climbed to 212 degrees. I had never seen that before but also had never been stuck at that speed uphill. Usually, the truck just pulls the TT up at whatever speed I want in 5th gear and the trans temps run anywhere from 170 to 185 max. It took a few minutes once I crested the pass before the temps came back down under 200. Then for the rest of the trip it was 170 to 180 or so. I guess it just did not like the gear it was in pulling up the pass. Is that temp of 212 anything to be concerned about? Or since it was only for 10 minutes or so and came back down, all should be good?
