jetrinka
Had a question about trailer tires.
Recently bought a Diamond C MDT dump trailer. The gross trailer weight rating is just under 10k (like 9980 or something...). Its a bit overbuilt with twin 6k axles under it and has load range E tires on it.
I normally like to switch out the factory tires with Goodyear Endurance. They make an E rated tire in my size (235/80R16) with a load rating of 3420 per tire - putting the total at 13680 - which IMO leaves quite a decent amount of "room for error". I've put Endurance on all my other trailers with no problems (5k TT, 3.5K Utility trailer) and have just preferred them over china bombs.....
Problem is I've had more than one person tell me now they'd upgrade to a load range F or even G tire which puts close to 20k of capacity.
Is there something I'm not thinking of? I tend to be careful with how much weight I put in a trailer - afterall my truck is a PW with Daystar cradles/bags so its not a super heavy hauler anyway. It seems to me the higher load ranges would be a complete waste. In the case of a larger trailer (something 14K or higher) or if I was some moron overloading everything the higher load ranges would give you room for error. However in my case it seems I'd just be trading ride quality, tire wear and suspension wear for more capacity.
Just wanted opinions and to know if I'm not thinking of something....
