ofishl1
I find a lot of posts around upgrading the rear to the Thuren track bar, appears to be mostly pointed at older Rebels, and PW's however little talk around the new CTDs track bars. I see the track bar on mine looks beefy so I assume its adequate.
However the rear Swaybar I see few discussions on upgrading it on new model year Rams, and wonder if most find it sufficient to do the job? My Ecodiesel swaybar was puny and when I put the Hellwig on it was a substantial difference being solid steel and not a bent tube. Are most finding the OEM swaybar is fine, or upgrading provides improved tow behavior with or without added weight /sway hitch systems? I will likley tow the trailer with and without depending on the distance, short hauls for overniters near our riding areas, but pulling up to 7000ft in the AZ mnts will likely put on some kind of trailer/ hitch system.
