buck79
Just wanted to throw this up here. Had a set of the new RT Pros mounted and balanced today for my 2020 Power Wagon. All stock suspension minus the Bilstein 5160's all around. The wheels they are mounted on are Method MR315 +25 offset. Tires are a 37x12.50R17. Initial impression is I like them. It is raining here today, and they are about as good as the worn 25K mile RT Trails they replaced. So "OK" in the wet so far. The ride comfort is excellent. I am currently running the fronts at 43 psi cold and the rears at 34 psi cold. You can tell they are a heavy tire. I weighed one tire here on a digital scale and got 84.6 lbs. They balanced with about 4-5 oz per tire. Run silky smooth down the highway. No weird vibrations or anything to speak of. They are a much more aggressive tire than the Trails, and I liked the Trails well enough off-road, so I will assume they should be superior to them in that environment. Love the look of them. Great sidewall. So with less than 100 miles on them, I can say I'm happy. One thing I will say is they run closer to 37 inches at 36.8 inflated, where the Trails were advertised at 36.5. I had no rub with the Trails after a few thousand miles, and with these tires I had to remove the little mud guards behind the front wheels, and actually looks like Ill go ahead and do the trimming that I should have done in the first place. The rub after removing those guards is very minimal. I could live with it until these wore a little if I was so inclined and stayed on the street.
