Towing capacity . Bumper and goose on my 24’ 3500?
Ramster3000
I did some searching off forum and on forum. I found the VIN look up tool.
24’ 3500 laramie CC 6‘4” box. “Loaded“ night edition. Missing air bags, sunroof. (Custom order)
says max payload 3,616 and max towing 23,096
assuming the max towing is goose/fifth wheel? Im a bumper pull only and wanted to find out what its rated for on the hitch. Thought I was around 19,000?
Thanks!!
Thanks!!
Your owners manual has those limits.
Generally you will hit axle limits long before you hit published towing specs.
Sort of…. Page 195 of the current 24’ manual.
Very general it says 3500 , 23,000lb on the hitch
37,100 on the gooseneck. I know that is not correct for my truck. It also says go to rambodybuilder.com which no longer exists….
Ram body builder does still exist, you just have to register for it.
Those are the correct limits for the hitches on your truck. You will hit your axle limits first, which are posted on your drivers door jamb.
