Gman1988
I am looking for advice or folks with similar setups that can provide me with some feedback on my situation:
We have a 2022 Grand Design Reflection 150 Series 280RS. As listed it has a UVW of 8566, a GVWR of 10995 and a hitch weight of 1384
I had a 2021 Power Wagon that I had modified a bit in order to tow but I felt it was still overloaded and not well suited for towing. It pulled the weight fine and stability wasn't an issue with airbags but it really struggled in the mountains (I live in the PNW) and I was averaging 7 MPG! When I say struggled, I mean it did it through even the steepest of passes but it definitely was working and I wasn't going to pull away from anyone. Not that this was a huge deal but it was! After hours of listening to the motor work that hard it can become stressful. I was not interested in a long stressful towing experience. The other stress was braking when coming down the other side. Again, not that it couldn't do it.... just that it seemed too much work for the truck to me and I prefer a safe buffer with no stress. If we were only travelling on short trips, it may have been fine but living in the PNW, you are always going over a pass if you are going on just about any trip.
Long story short.... I waited until the recent factory incentives and found what I thought was the right truck for me. Now after looking through many posts on here and in my 5th Wheel forum, I am seeing where many members are stating things that have me a bit concerned. Maybe they are speaking from a generalized standpoint, and they don't fully understand the specs for our 5th wheel. Or maybe it's just guys with 1 ton trucks that are rated to tow massive units spouting off because their rigs are so impressive? Please don't judge but there are reasons why I went the direction I did. I don't want a lecture on what I should have done, I just want real world opinions or advice from folks that have similar setups. I would also like recommendations as to hitching gear since I am starting with a fresh slate.
I now have a 2023 Ram 2500 Laramie SBCC 6.7 Cummins with the towing technology package. It also has the off-road package which I could have done without but it was what was available considering my wish list and late year inventory. The off-road package may be an important data point when considering my choices going forward. I couldn't find one with the factory 5th wheel prep so I have options there to consider when deciding my final setup as well. That's not a big deal. I wish I would have got the factory air but I couldn't find one with that either. I can also work around that. I just really wanted the towing tech. My payload is admittedly lower than I would have expected for a 3/4 ton truck @2206. I had a Ford F250 previous to my 2021 Power Wagon and it's payload was quite a bit better. I just always went back to the memories of towing with a diesel and would daydream about it! I finally just pulled the plug and did it. I am happy with my decision but again, looking for help from any of your who are in a similar situation. Hopefully some of you are pulling the GD 150 Series or something similar in specs. Ideally with a 3/4 ton truck and can offer some real world perspective. Coming from my previous situation, I thought I was going to be in a much better situation and I am sure I will. The goal is the best, most comfortable towing experience that is safe. The reason for going 3/4 is like many on the forums, I was looking for comfort and maneuverability as a daily driver. I am not restricted to driving it daily (I have other vehicles) but would prefer to drive it the majority of the time here in the PNW. I probably would have gone with a 1 ton if they had one that met my wish list but again, late year inventory was an issue.
If you had it to start all over, what would you do for a setup in my situation. 3/4 ton Ram, Short Bed (6.5' box), no 5th wheel prep so far, 2206 payload limit and a Curt Turning Point (Locked so far) pin box. In all of my travels with my 2021 Power Wagon with a 6.5' box, I never really felt like clearance was an issue with my 5er. Even in the most extreme turns, it didn't seem to be an issue with the 150 series narrower RV. Granted I had a B&W Patriot slider but I didn't seem to really need to use the slide. So I would like to know if you are running a similar unit with a 6.5 box and what setup is the best? Should I unlock the Curt Turning Point and use something with it? I had to take out the B&W Patriot when I traded in my truck and OMG.... never again. I wish to have a clean bed setup so that is very important to me as well. I am leaning toward the flip gooseneck ball and B&W Companion but I would like to hear what everyone else thinks or would do in my situation.
I look forward to the advice....thanks in advance.
