Tow chain or tow strap?
RV_Goose
My last chain got left on a trailer holding down a tractor. Pretty sure it was a 3/8 chain. Looking at tow chains to have on hand as I have needed them 6 times in the past 2 months, And I did not have any. I see 3/8 welded chain (AgriSupply), 20ft, that comes with the hooks. They also have the 3 inch tow strap in 20 feet lengths. In the mud bog in Eastern NC right now, I had to get pulled out 3 times, and pulled out 3 others.
In snatching out some trucks (an easy pull didn't work) The chains work. I am not sure the tow strap would have held together.
3/8 is pretty heavy duty and will probably do all I desire. Lighter chain I am not sure would hold for snatching. I've done it for tree stumps and vehicles.
What do yall use?
When chain snaps it's a very, very bad situation. There are snatch straps and tow straps, the former is dynamic and the latter is static. I carry both for different situations.
X100. two completely different uses. of snatching get a bubba rope. it is the stretch and recoil that gets someone unstuck if buried.
Dont use chains i have seen enough dented tailgates and busted out rear windows with mild tugs, straps are rated much higher than chains.... or a bubba rope like mentioned works great
I carry both and use the appropriate tool for the job.
Hate to wrap my nice pull straps around a fallen tree blocking the road. Hate to try to pull stuck vehicle with a heavy chain. Sometimes you need both to protect your gear and the object you're tugging on.
Is there a huge difference with Bubba rope brand and the others?
On paper I would assume all kinetic ropes would be the same. I have only ever used the true Bubba brand as that is what I have, but if I was buying again I'd look at specs before the name.
Nylon 3 stand..1 1/4” rope..used it for years and pulled many a vehicles out of ditches. over 40,000# breaking strength
Definitely a recovery strap for me. Tow ropes and chains break on the jerk. Really need the stretch and recoil action for those tough stuck times.
I'm looking into the bubba rope as well as other brands. I also watched videos that state the straps and ropes are only good for a certain number of pulls. But as I am not a pro doing it all the time, I hope to not hit that limit.
A strap is the best option for you, your not pulling people out of swamps so a kinetic rope is a waste... i have had the same 35ft strap good for 80k for about 10 years its been great pulled many vehicles out
Well, most of the eastern half of North Carolina is either paved or mud. ;) :)
Definitely a Tow strap, snatch strap, recovery rope. Call it what you like
Chains are NOT the right tool for the job.
my recovery bags each have multiple snatch blocks, multiple d rings, tree straps, tow straps, winch line extension ropes, etc. but they include zero chains.
Chains have their spot holding **** down on the trailer thats about it
Also tow straps with steel hooks ... big no-no
soft loops on either end.
to make a closed system use d-rings
I wish i had a picture of my old 03 chevy work truck hood from my younger days with a hooked strap it went through the leading edge of the hood and i was hardly pulling...
