2manyprojects
Titan 30 gal aux spare fuel tank
I’ve rec’d multiple inquiries and didn’t see much info on our forums for this tank since I installed it a year ago, so I thought I’d provide some details and my experiences. I performed the basic tank install April 2021 w/ 2900 mi on my truck, with about 20K miles driven since. My truck was purchased to pull an off-road trailer and I’ve got multiple other trucks w/aux and o/size tanks, so I really wanted something for my Tradesman. Going to 37” tires prevented using the OEM under bed spare location, so the tank seemed perfect to substitute. I did consider the o/size main tanks also available but wasn’t crazy how most are lower than the OEM tank and frame rail; I can still go this way in the future. I also was concerned with the CP4 pump warranty issues for the new truck and didn’t want to modify the OEM fuel system initially.
The Titan kit is quite comprehensive, provided everything needed, with thorough instructions and well written. There are also YouTube videos which further helped clarify details. Titan was very helpful when contacted with questions on the function of the transfer pump and controller. Their tech person explained the pump needs to flow fuel at a slow rate (30 gph), otherwise the Ram fuel system will signal problems as they learned it can’t cope with sensing the fuel increase too rapidly while driving.
I elected to sub some components for personal taste, but quality was acceptable. The supplied low pressure fuel pump never worked for me; I decided to use a better-quality solid-state pump I got locally from NAPA. I didn’t discover this until well after I had purchased, so I didn’t approach Titan for a replacement.
I also made a few custom mods for my use, detailed later.
Installed pics
Pros
Cons
SUMMARY: I’m very satisfied overall. On board fuel has doubled, while I can selectively transfer as desired. The controller is straightforward, and the system works. With my mod, I can transfer fuel other places if needed. It adds weight to the rear axle, which I value in the winter, but has presented some challenges in how I load when towing. I can feel it when full driving, but it’s not detrimental. Unfortunately, the price has dramatically increased since I purchased, and makes the value harder to justify. I think it’s more versatile than an o/size replacement tank, but the cost difference has changed.
Installed pics
Pros
- Range between fill-ups; w/ 60 gals onboard, I’m able to go at least 900mi highway cruising (500 towing).
- Doesn’t occupy bed space, although my choice of fill location requires in-bed access.
- Adds 250lbs weight to the rear axle, for winter traction.
- Pretty much invisible on truck.
- Tank and peripherals are light, molded plastic less than 50lbs.
- Extends time between fill-ups when not traveling; delays dealing w/ current crazy fuel costs.
- Functions w/ Ram systems w/o issues.
Cons
- Price has increased greatly since I purchased 1.5 yr ago.
- Takes up spare location.
- Adds 250lbs behind the rear axle.
- Requires cutting into the bed to install fill port.
- Cost for a total fill.
- Tank is molded plastic, thicker wall than OEM tank, is similar to MFC’s (mil fuel can) but even heavier duty. I’m impressed with the construction, but it isn’t steel, if that’s your comfort zone.
- Occasionally leaks a small amount of fuel from the tank breather. I’ve traced this to filling the tank and topping off too much in the morning, then getting a significant temperature rise during the day. I now fill w/o topping too much and transfer a small amount of fuel when the main tank slightly empties.
