Tire Wear
GBB
Noticed the passenger front tire is showing wear on the outside but driver side looks normal. Thinking bout taking it in for alignment check. Has anyone used the Thuren alignment specs with zero toe-in? If so how did it work out.
Had the same issue with my '21 PW. Was noticeable at about 2K miles.
Took it to my tire/alignment shop and worked with the guys there. Aligned to Thuren specs on toe and adjusted the Castor to 3.5 degrees insted of their 4.5.
20K miles later and tires wear even. I rotate every 5K miles with my oil changes. Running 45/37 pressure hot. Truck tracks true and straight. No issues, even when over loaded and towing a 6K trailer.
Thanks..
Where can I find the Thuren specs?
