Tire upgrade SPARE question
Jeeptree2112
So when upgrading from stock 33's to 35's, what is everyone doing for the spare tire? Keeping the OEM one in place or is everyone buying 5 tires. Coming from a bunch of lifted jeeps that's all I ever did.
Buy 5 tires unless you don't mind potentially changing 2 tires if you get a flat. i have a 35" Cooper STT Pro under my truck, snug but no issues.
I buy 5 tires.
Falken 285/65R20 just squeaks into the spare location. Mfr claims 34.6"
RAM uses the same 18" spare steel wheel on all trucks so it may be different than the 4 wheels you have.
this gets discussed over and over and many people say you can not get a 35" tire up there but many people say you can...I have done it on two 2020 2500's a nitto ridge grappler and a Toyo RT which are on the larger size of most 35's. Some 35's run smaller ie bfg and coopers.
I buy 5 tires.
power wagons use a 17" wheel.
just need to use some proper technique
I installed a 35 on the factory rim of my 2014 2500 and it fit but required some persuasion. On my 2020 3500 I used a 285/75R18 on the stock rim and it fit a lot better and doesn't hang near as low. I just go on ebay and look for a used tire in the size I want. I'm not spending $300 for a tire that will never get used.
