Tire change, floor jack and alignment settings
4CEFEDV
Getting new tires and an alignment. Before leaving the tire shop should I check off the tire change, Jack and alignment settings in the settings menu of the truck?
I doubt the tire shop is going to remember to do it even if I tell them.
Once they go above 5 mph it will remove the selection and return to normal mode. You can ask them to do it, but I don’t actually think it makes much of a difference.
Be sure to give them Thuren alignment specs.
