If you get a 2" lift coil and don't install a new shock or a shock extension you are limiting your down travel, because you are asking the shock that has a 10" stroke to move longer than 10" now. If you leave the same shock and install an extension you are still at a 10" stroke but now you are limiting your up travel. Now the spring can essentially compress a further 2" from the factory coil. If you have shocks meant to do it or have bump stop drops you are fine, but if the shock can't compress as much as the spring can you are bottoming out the shock and turning it and associated components into your bump stop. Will you ever notice? I have no idea, but I've seen enough broken lower shock mounts with shock extensions bolted to them that I figured I would caution you.
