havokeachday
I recently traded a '21 ram 2500 w/ aftermarket airlift suspension for a '24 2500 longhorn limited w/ 5th wheel prep and air suspension hoping that the air suspension would give a good towing experience. I immediately found out that it is the most terrible thing ever. In fact, it is only marginally better than my '10 that has 6" of deadzone in the steering and a 6" lift.
I tow an aluminum 28'ft cargo trailer that is 4k empty and has a payload of 10k. I usually have only 20 gallons of fuel, 5 dirt bikes at most, 30 gallons of water and miscellaneous tools - my payload is under 3k lbs. My '21 towed this like a dream. No issues with wind, no issues getting sucked in by a semi when passing or getting passed. In fact, it was nearly as stable as a dually. I ran it when towing with 25-35 PSI of air in the airlift 5k bags.
My '24 is sketchy to the point that I wouldn't let an inexperienced driver even attempt a highway tow with my trailer, however my 21 I would have let anyone try. I've not changed anything on the trailer. I used my '21 to haul my bikes and gear 1200 miles, and used the '24 to tow everything back. The '21 even w/ minimum air pressure in the aftermarket air system was way better.
Specifically, the problems are:
1. Get's blown around by wind.
2. Get's sucked towards semi's and other large vehicles when passing or getting passed.
3. Have to apply a second correction as it wants to sway back and forth.
The differences between the 21 and 24, spec wise are:
1. 21 has aftermarket (airlift) air suspension
2. 21 was megacab rambox
3. 24 has all what I think are all the towing options - trailer backup, air suspension, trailer camera package, 5th wheel prep.
I am flabbergasted at just how bad my 24 tows the same exact load that my 21 did flawlessly and even my 10 did a better job. I load the trailer the same way every time.
Thanks!
Thanks!
