M McGuyver Member Messages 46 Reaction score 16 Points 8 Dec 3, 2022 #1 Just got 2022 3500 dually. Where is the engine temp guage? 6.7 ho. See trans temp but no engine temp
flan Well-Known Member Messages 4,835 Reaction score 10,819 Points 113 Dec 3, 2022 #2 McGuyver said: Just got 2022 3500 dually. Where is the engine temp guage? 6.7 ho. See trans temp but no engine temp Click to expand... What trim level do you have? Dashboard EVIC are different between levels.
M McGuyver Member Messages 46 Reaction score 16 Points 8 Dec 3, 2022 #3 flan said: What trim level do you have? Dashboard EVIC are different between levels. Click to expand... Level 2
AH64ID Moderator Staff member Messages 5,208 Reaction score 5,414 Points 113 Dec 3, 2022 #4 McGuyver said: Level 2 Click to expand... Of what? Laramie? Tradesman? Etc… You can likely find it under settings to customize your EVIC.
M McGuyver Member Messages 46 Reaction score 16 Points 8 Dec 3, 2022 #5 AH64ID said: Of what? Laramie? Tradesman? Etc… You can likely find it under settings to customize your EVIC. Click to expand... I found digital guages under off roead on u connect screen. Gives actual temp.
AH64ID Moderator Staff member Messages 5,208 Reaction score 5,414 Points 113 Dec 3, 2022 #6 McGuyver said: I found digital guages under off roead on u connect screen. Gives actual temp. Click to expand... You still haven’t said your trim level, but off road pages tells me you have a premium EVIC. You can change the EVIC gauges to many different things.
M mountainears Well-Known Member Messages 614 Reaction score 463 Points 63 Dec 3, 2022 #7 Check the manual. Explains how to change / configure the gauges in the dash cluster (EVIC). Sent from my iPhone using Tapatalk
