Streamlight mount?
mountainears
Anyone find a good spot to mount a streamlight?
Had a fleeting thought putting it here but the console slide won’t click forward. Would like a spot accessible by the driver.
Maybe if you use a tablet holder that mounts in the rear cup holder behind the console. You could reach the rear AC module easy enough.
I put it on the passenger side of the console. I have no problem reaching down from the driver's seat to remove it.
You just tapped the screws right through there so they stick through inside that pocket? Wouldn't bother me as I don't use that pocket, but curious.
Yes, but they are forward of the pocket. I also used some double side tape for a little extra support. I did go back and cover the wires to make them less noticeable. It is wired to my auxiliary battery full time.
I ended up giving the drivers side a shot. Seems to miss my leg positioning and easy access. IMG_4184.jpeg
