stock fuel tank wires connector part #?
GD Transport
Does anyone know a part number or where to find both a male and female version of the stock fuel tank connector plug? I have a 2024 3500 Mega cab Cummins 31 gallon tank. I assume it's the same plug as the crew cabs but Just guessing.
I'd like to make a plug and play removable short harness that plugs in between the stock wire harness and the tank. I just want a tap off the stock gauge without cutting into the factory wiring like I did on my 2018. I'll tap into the jumper rather than directly into the factory wires.
Depending on how much it would cost , I'm open to someone making me a custom harness as long as it's quality and the connections are watertight.
Also open to other jumper locations where I could achieve the same thing without leaving permanent evidence in the wiring.
Thanks
If you mean the plug that goes into the top of the fuel tank module, it's a GM part:
I used that one when adding my midship tank. I don't know if there's a male version out there.
Yes that's what I'm looking for, Thank you. Even better that it comes as a pig tail. Now If I can find a male version I'll be set. Thanks again.
