Hello all, I recently purchased my first new 2022 big horn ram 2500 6.7. I noticed on the three hour ride home from the dealership that it was slightly wandering on the interstate. I rode it for two weeks to see if it got better but it didn't. I already decided that I wanted to level it so I waited to have it aligned until I bought a RC 2.5 inch level. I got the leveling kit and had it installed and had it aligned to factory specs and it still wandered, did some research and had it aligned again per Thuren specs (0 toe, low end of the caster specs recommended by thuren for the diesel models) and it still wanders. I'm not sure the exact alignment because I didn't think to ask. The steering wheel also will not return to center and did not from the dealership either. It's really becoming a hassle. I'm now running 60 psi all the way around but have tried higher and lower with no noticeable difference. if anyone has a suggestion or the optimal alignment specs, it would be greatly appreciated.
Also, I understand this is my first solid front axle, but I have had two duramaxs in the past. It's not the case of "not being used to a solid front axle" I have driven a stock 2017 cummins many times that drove fine on 35's, so I know that's not the case. Thanks again
