[SOLVED] OEM LED Headlight Conversion - No Turn Signals?
01Time
Central Texas Hill Country
Has anyone else swapped out halogen headlights for OEM LEDs and the turn signals won't work?
Here is what I did in AlfaOBD:
Code:
Car configuration change: LED Front Turn Lamps Present: ' NO ' -> ' YES '
Car configuration change: LED High Beam Lamps Present: ' NO ' -> ' YES '
Car configuration change: Front Park/Signature Lamp Left - Pin A-7: ' NO ' -> ' YES '
Car configuration change: Front Park/Signature Lamp Right - Pin A5: ' NO ' -> ' YES '
Car configuration change: Signature Light Present: ' NO ' -> ' YES '
Edit (these were also changed, but were inadvertently left of the initial post/list):
Car configuration change: LED low beam lamps present- YES
Car configuration change: LED front park/marker lamps present- YES
And here are the error messages:
Code:
Error code: B2204
ECU Configuration Mismatch
Incorrect component installed
Last test completed positively
Error intermittent
Failure warning lamp 'ON': Not requested
Error code: B1756
Front Right Turn Lamp 2 Control
Short circuit to + battery/Open circuit
Last test failed
Error present
Error code: B1757
Front Left Turn Lamp 2 Control
Last test failed
Error present
Error code: U0232
Lost Communication with Blind Spot Detection Module
(This is an ongoing issue...waiting for a new module under warranty.)
Last test completed unsuccessfully
Error present
In my notes from when I did this I have the following:
CBC features LED front turn lamp present- YES
CBC features LED low beam lamps present- YES
CBC features LED high beam lamps present- YES
CBC features LED front park/marker lamps present- YES
CB C Config I/O Usage front park/signature lamp left pin A7- YES
**2014 CBC Config I/O & Feat. Front park/signature lamp right pin A5- YES**
**Note** If you do not see this 2014 CBC setting, then use this one:
2014 CBC Config I/O & Feat. Truck bed lighting feature- PRESENT **
CBC Extern.Light Calibr.: Signature light present- YES
hmmmmm...I think I remember changing:
CBC features LED low beam lamps present- YES​
CBC features LED front park/marker lamps present- YES​
but those aren't on my configuration change list...let me go out and double check...
They were set to YES, not sure why they didn't show up on the change list.
Interestingly, I cleared the faults with AlfaOBD and when I started my truck, the turn signals worked for about two seconds before they stopped and the 'turn signal out' notification popped up on the EVIC and the other signal lights began to hyperblink.
I have disabled the diagnostic function on my turn signals so I can replace the bulbs with LED and not worry about bulb out messages. I believe I searched for diagnostic to find the from left and front right settings. But I did have an issue with one side when I first installed. Shut everything down and waited about 20 mins and they have worked ever since.
Apparently the settings depend on which LED headlight you have. I've got the Adaptive LEDs and there are a few more changes to make with AlfaOBD for them to work. As always, Jimmy07 is the man.
[SOLUTION]
Here’s the full list of settings to confirm for the adaptive headlights (fog lamp settings are included too):
CBC Features: LED Front Turn Lamps Present- Yes
CBC Features: LED Front Fog Lamps Present- Yes
CBC Features: LED Low Beam Lamps Present- Yes
CBC Features: LED High Beam Lamps Present- Yes
CBC Features: LED Front Park/Marker Lamps Present- Yes
CBC Config I/O: Right Dedicated DRL Lamp/Right Signature LED Present...- No
CBC Config I/O: Left Dedicated DRL Lamps/Left Front Turn Signal #2...- No
CBC Config I/O: Connector A Pin 01 and Connector D Pin 13 Front Fog Lamps Output Present- Yes
CBC Config I/O Usage: Front Park/Signature Lamp Left- Pin A 7- YES
2014 CBC Config I/O & Feat: Front Park/Signature Lamp Right - Pin A5- YES
2014 CBC Config I/O & Feat: Headlamp Module LIN Diagnostics Line Enabled- YES
CBC Extern.Light Calibr: Signature Light Present- YES
CBC Extern.Light Calibr: Redundant Front Turn Signal- NO
CBC Extern.Light Calibr: Signature Dropout Enabled- YES
CustSetMenu 1: Adaptive Front Light system CSM Present- YES
P/T Chassis Net: AFLS Discharge Lamps- Enabled
