SOLD - Edge EZX - 19-22 6.7 Cummins - $300 shipped
Status
Not open for further replies.
AZCummins
Bought this used and ran it on my truck for several months. Removed to go with a Calibrated Power Tune. Mostly just used it for EB memory, throttle sensitivity, tire size calibration, and TPMS changes so do not have much feedback on power levels as I left it on stock setting with +3 throttle sensitivity.
One clip has small piece broken - pictured in last photo
Asking $300 shipped in continental UPS via UPS ground
From website:
Features:​
  • 5 Power Levels Adjustable on-the-fly through steering wheel controls
  • Level 1 - 20hp/55tq, Level 2 30hp/70tq, Level 3 40hp/90tq, Level 4 50hp/110tq, Level 5 60hp/130tq (Peak to Peak Gains)
  • User adjustable throttle booster settings in each power level via app
  • Tire Size Speedo Calibration via App (Up to 40" Tire Size)
  • Button Recall Enable/Disable via app - Remembers Tow/Haul and Exhaust Brake settings
  • Turbo Timer Setup and Enable/Disable via app - Once enable, feature will work on every engine shutoff cycle
  • Tire Pressure Monitoring Sensors Enable/Disable, Warning On/Off, and Pressure Threshold adjust via app
  • Engine High Idle adjustable through steering wheel controls when in Park
  • Max Cruise set speed adjustable via app (Set max cruise speed at 40-97mph)
  • Gear Display in Drive on factory display Enable/Disable via app
  • Fog Beams with High Beams Enable/Disable via app
  • Gear Ratio Calibration via App
  • Manual DPF Regen via app
  • Read and clear ECM/TCM diagnostic codes via app
  • Check Emissions Readiness monitors via app
  • Engine Coolant Protection (Module adds no power until 120-degree ECT, backs down power at 240-degrees ECT)
  • Now supports 2019-2024 Ram Cab & Chassis 3500/4500/5500
Status
