Snow Plow on 2021 PW?
rbmiles
Took a 75th anniversary edition PW for a ride the other day and LOVED it! Only catch is that I need to be able to put my fisher plow on it. Not planning on doing commercial plowing just need to be able to plow my paved driveway
After doing some looking it appears that it may not be possible due to issues with the winch. Does anyone have any information on if it is possible? If I were to remove the winch, would it be possible?
I appreciate any help you can provide.
The way the fisher brackets are you will need to remove the winch and winch plate other than that it should be good the support brackets that go to the sway bar may need to be modified if the disconnecting sway bar is bigger than non pw trucks
Thanks for the reply. The plow is priority one, but kinda bummed that I'll have a big hole where the winch used to be.
May be able to use a bumper insert from a regular 2500/3500? I dont know if the pw bumper would be the same opening
