Sloppy gear selector......
oscar
The handle flops around, I'd say 1/2" + in all directions. You can do a nice circle with the end. Works fine, and it's been like that for a long time. Still, feels like a farstener somewhere is loose and if it falls out........
This normal? How to fix if not.... thanks.
Screw at the base of the handle comes loose. Pull the boot, tighten the screw, install the boot.
I did that twice before I added some locktite. Don't drop the screw!:mad:
That's what I needed. Thanks. (And I have some "red".....)
OK, that was easy. It is a 10mm phillips/hex head. Can't get the screw driver in there without removing trim from the steering column, but was able to wiggle a small 10mm wrench in there. All better. Thanks again.
