Skinny 35s
el_barto
Anyone running skinny 35s (35x10.5) on their PW? Looks like there are a couple companies that make them, like the Kenda Kleaver RT. Skinnier would theoretically be better in snow/slush since it cuts into the snow. Downsides, less footprint when aired down for deep snow or sand; and if you need a replacement it’sa less common size to find.
Or it might make sense to just use as a spare, it will keep the same diameter if you have 35x12.5 / 315/70 but not hang down as low.
just food for thought
Nitto has a 35x11.50 in the Trail Grappler. Excellent tire and an awesome size!
I've always been a fan of "pizza cutters" but don't really see many fullsize rigs running them.
unfortunately it is only c rated. Great jeep tire tho. Interco makes some awesome pizza cutters.
Pizza cutters are fairly popular with the Toyota offroad crowd (where I come from previously). Seems the taller you go from the 33, the less common they are.
I ran a 285/75R17 toyo open country at2 and I was a fan. I prefer narrow tires though, that is just a 34 though. Assuming the power wagon comes with a 18" spare a 285/75R18 fits perfectly up there and doesn't hang much lower than stock.
Power Wagon has a 17” spare
I love pizza cutters.
Post pics when done
Currently running 35x11.50 (285/75-18) on my ram and 37x11.50 are my next most likely
Just curious as to what advantage there is to running a skinny tire, other than maybe rotating mass? I am on 35x12.5 and really want them fatter, but the factory wheels are only 8" wide. Around my neck of the woods, being near the beaches and with mud, I want the fattest tire I can get.
Fuel Mileage, Rubbing, Better Braking, Better road manners.
Wider is typically better offroad because it allows a wider footprint = better grip.
But on road, the wider footprint equals more rolling resistance which results in worse gas mileage, and can make low speed turning more difficult. Skinnier can also help with fender clearance on some trucks (not really an issue on Power Wagons which fit 35x12.5 without issue). Skinnier is better in snow/slush on the highway as it cuts thru better. In deep snow offroad however, wider+airing down is better so you don’t sink/rut out the trail.
Many people will say when airing down that most of your grip comes from the longer foot print and not a wider one. Meaning it's more important to have a taller tire than a wider tire. I would concur from my experience. Width is great for side to side grip (lateral G's) and height (a longer foot print) is great for forward grip and braking.
Not to mention all the benefits of saving weight with a skinnier tire.
