size of rear diff
leeroy300
Do the 3500 ctd’s ho have a larger rear diff?
clutch style sux, maybe a bit smoother but not worth the strength sacrifice
so we need different gear oil
I am running Red Line which is LS compatible. Amsoil SVG is also.
Good to know for the AMSoil.. was wondering if I needed to get the AMSOIL Slip Lock to add to the rear diff...
amsoil says to add the slip lock when used in diffs with LS. i just changed gear oil and i added the slip lock.
AMSOIL SEVERE GEAR is compatible with most limited-slip differentials. For applications that require additional limited-slip friction modifier, add AMSOIL Slip Lock®.
