Service trailer brake system
Brad83
I was pulling my fw camper back to it's storage spot today and the service trailer brake system warning popped up. The trailer disconnected light also came on. I only had a few miles to go and the want a good spot to pull over so I kept going. It seemed like I didn't have any trailer brakes. The temp on the rear trailer you're was also high. The left was 123⁰ at one point and the right was 111⁰ . The front tires were 88⁰. I want print very close attention to that so I don't know how long they were they way. When I dig stop I could tell the back brakes were definitely dragging. After I got the trailer parked and unhooked I shut the truck off. When I started it up the trailer brake system warning came on. I made a couple stops on the way home and each time the warning came on too. Does this indicate there is a problem with the truck? I've got an appointment at the camper shop to replace a couple slide seals Tuesday so I'm gonna have them check the brake system and make sure I didn't burn out the grease or damage the wheel bearings.
