TD_Wubs
Backstory - needed new tires for ‘21 Hemi NE. Settled on 35x12.5 (or 295/65) on factory NE 20s. On Black Friday fired up Discount Tire website to buy the new(ish) Falken Wildpeak R/T. 50k tread warranty, 10-ply, E load. Decided to research the tire just a little further on the Falken website. Found that they offer a 37x11.50, that weighs less than the 35x12.5 and only 5 lbs more than the 295/65. Anecodotal evidence (ie, limited forum postings) indicated that the 37x11.5 could fit with little to no rubbing. Pulled the trigger on the 37x11.50s. They ended up costing slightly less than either the 35x12.50 or 295/65 tires, so kinda a no brainer.
Suspension lift was not in the budget but i moved on the Thuren sway bar. Installed last weekend. Took the factory wheels/tires to Discount Tire this morning and they swapped on the new tires - they wouldn't install the 37s on a factory suspension truck.
Great news - the fit is flawless. No rubbing whatsoever. Sway bar provides clearance in the front. No rubbing on wheel well liner or radius arms. No noticeable loss in power or acceleration. The sway bar plus the increase in sidewall has led to a better ride. I'm so incredibly stoked that the new rubber looks so good and fit so well.
I'll post again with an update after living with them for a while.
